Yanmar 4LHA-DTP, kan jeg etterfylle med Biltema Longlife G30?
pipati
Hei,
Jeg har Havoline LLC på den.
Kan jeg etterfylle med Biltema Longlife G30?
Brukerhåndboka sier at man ikke skal blande ulike fabrikater av LLC væsker.
2) Choose LLC which will not have any adverse effects on the materials (cast iron, aluminum,
copper, etc.) of the engine's fresh water cooling system.
Consult your Yanmar dealer or distributor on the use of coolant /antifreeze, and detergents.
The coolans/antifreezes, which are good performance for example, are shown below.
TEXACO LONG LIFE COOLANT ANTIFREEZE, both standard and pre-mixed.
Product codes 7997 and 7998.
HAVOLINE EXTENDED LIFE ANTIFREEZE/COOLANT.
Product code 7994.
4) Do not mix different types (brand) of LLC, chemical reactions may make the LLC useless and
engine trouble could result.
Share on other sites
