Seiling er bedre en sex fordi..
Guest Avmønstret#
Guest Avmønstret#
REASONS SAILING IS BETTER THAN SEX:
- You don't have to hide your collection of sailboat magazines.
- It's perfectly acceptable to pay a professional to Sail with you once in a while.
- The Ten Commandments don't say anything about Sailing.
- If your partner takes pictures or videotapes of you Sailing your boat, you don't have to worry about them showing up on the Internet if you become famous.
- Your Sailing partner doesn't get upset and really does forget about people you sailed with long ago.
- It's perfectly respectable to Sail with a total stranger.
- When you see a really good Sailor, you don't have feel guilty about imagining the two of you Sailing together.
- If your regular Sailing partner isn't available, they won't object or criticize if you Sail with someone else.
- Nobody will ever tell you that if you Sail by yourself, you’ll go blind.
- When dealing with a Sailing pro, you never have to wonder if he’s really an undercover cop.
- You can have a Sailing calendar on your wall at the office, tell Sailing jokes, and invite coworkers to Sail with you without getting sued for harassment or sex discrimination at work
- There are no Sailing-transmitted diseases.
- If you want to watch Sailing on television, you don't have to subscribe to the Playboy channel and you don’t need to feel guilty watching on the family TV.
- Nobody expects you to Sail with the same partner for the rest of your life.·
- Nobody expects you to give up Sailing if your partner loses interest in it.
- Your Sailing partner will never say, "Not again? We just Sailed last week! Is sailing all you ever think about?"
Og en ganske underholdende tråd videre i forumet:
http://www.sailnet.com/forums/general-discussion-sailing-related/104976-sailing-better-than-sex.html
Feks: ugly boats get sailed without the help of alcohol
Ja det er teit, men litt morro også :-)
Guest Avmønstret#
Prøver på en norsk oversettelse:
Hvorfor er seiling bedre enn sex?
  • Du trenger ikke å gjemme unna båtbladene dine
  • Det er greit å betale for å få med en profesjonell som mannskap av og til
  • De ti bud sier ingenting om seiling
  • Om din partner tar bilder eller filmer av seilingen trenger du ikke være redd for at det havner på Internett om du blir en kjendis
  • Din seilpartner bryr seg ikke om hvem du har seilt sammen med før
  • Om din seilpartner ikke kan så er det ingen som bryr seg om du seiler med noen andre
  • Ingen påstår at du blir blind av å seile alene
  • Når du seiler med en profesjonell seiler så trenger du ikke å lure på om det er en undercover politimann/kvinne
  • Du kan ha seilkalender på kontoret, fortelle seilervitser og invitere kolleger på seiltur uten å bli avskjediget på grunn av sekspress på jobb
  • Det er ingen smittsomme seilsykdommer
  • Om du vil se seiling på TV trenger du ikke å abonnere på lugubre kanaler og føle deg skyldig når du ser det på familie Tven
  • Ingen forventer at du skal seile sammen med samme person hele livet
  • Ingen forventer at du skal slutte å seile om partneren din mister interessen for det
  • Din seilpartner vil aldri si, "Ikke nå igjen, vi seilte jo forrige uke, er seiling alt du tenker på?"
  • Også stygge båter blir seilt uten at man må skjenke seg først
  • Du kan slippe luft uten at noen bryr seg når du seiler
  • Når du er 80 kan du fortsatt heise storseilet akkurat når du vil
  • Du kan seile andre folk sine båter, faktisk spør de ofte om du vil være med
  • Du skammer deg ikke om seilet faller i sammen
Mulig de de ti bud ikke gjelder ombord hos dere - men det er liknende bud blandt oss som er Maxieiere som er likeså strenge.
Jeg har byttet båt en del ganger. Jeg har også kikket litt for mye på FINN, og blitt fersket.
En gang ble jeg under press truet til å love følgende høytidelig, med høyre hånd på Maxiboken:
1. Du skal ikke ha andre seilbåter enn din Maxi
2. Du skal ikke begjære andre seilbåter
3. Du skal ikke begjære din nestes styrmann/ rederinne/ admiralinne (velg det som passer), andre deler av hans mannskap, eller noe av det utstyr han har ombord
osv osv.
Jeg er Maxi-eier jeg også.
Men jeg har ikke bestemt meg for valg av seilbåt ennå!
uansett er det likheter mellom damene:
  • Hun bør for eksempel styres av en mann
  • I et ubevoktet øyeblikk tar hun styringen
  • Tåler ikke overbelastning
  • Kan ikke rigges uten en manns hjelp – iallfall ikke når hun skal ta på diamantsmykkene sine.
  • Hun bytter som regel navn når hun bytter eier
  • Hun koster mer i underhold enn hva mannen hadde tenkt seg
  • Kan dra med seg en mann ned i dypet
  • Må sparkles og males før hun skal ut
  • Men det verste er at hun med årene kan gå litt lekk og bli besværlig og vanskelig å håndtere
