111baat Startet 25.September.2014 Link til dette innlegget Startet 25.September.2014 Hei Bruker merketape fra Brother utvendig(hvit med sort tekst) Problemet er at teksten forsvinner etter ca halvår. Noen anbefalinger på mere holdbare typer? Sitér dette innlegget Link to post
Worry II Svart 25.September.2014 Link til dette innlegget Svart 25.September.2014 Du må bruke tape i utgave TZe, den er mye mere holdbar. Brother har dette. . Brother Ptouch Tape Types: Laminated tape (TZe tape):Laminated tape sticks to virtually any surface and is durable enough to withstand scrapes and abrasions. Because it's water resistant, it can be used outdoors, as well as indoors. It shrugs off spills of any kind; from water, to oil, to chemicals and won't fade under harsh UV rays. And it stays on through hot and cold environments from freezers to microwaves. Brother has laminated tapes down to a science, these labels are ptouchtough. -> Resistant to water, sunlight, chemicals, heat and cold -> Can stick to virtually any surface -> Are durable as they won’t fade or tear -> Can be used indoors (such as microwaves and freezers) as well as outdoors -> Labels do not leave a sticky residue when they are removed, leaving a smooth, clean surface Sitér dette innlegget Link to post
111baat Svart 25.September.2014 Emnestarter Link til dette innlegget Svart 25.September.2014 Takker, da er jeg opplyst Skal sjekke div butikker I ettermiddag Sitér dette innlegget Link to post
