Seastar
Seastar
Her er et knippe forandringer som også er implementert i beta-versjon .0119, - men som dessverre falt ut i Changelog-oversikten jeg la inn tidligere:
xx. When GRIB and tide/currents are both visible, then tide/current calculations are shown at the "GRIB time".
The color of the tide/current "widgets" change is to notify the user that the tide/current reference time has changed from "local NOW time" to "GRIB time".
xx. Now a course predictor is shown even when the actual AIS target, or the end point, is not visible on screen.
xx. Implemented user selectable SOG/COG calculation from position data. If not available trough normal NMEA.
xx. Add US Pilot charts to the chart sources in the chart downloader.
xx. The "Course-Up Update Period" feature has a new name to better describe what happens: "Chart Rotation Averaging Time"
xx. "Help handle" for dragging waypoints in touchscreen mode
xx. The feature: "Make line and polygon smoothing optional in OpenGL mode"
Ellers litt nyttig info fra denne tråden med bl.a denne henvisningen til bruksanvisningen vedr. diskusjonstema til Joltus / Roger jo:
http://www.cruisersforum.com/forums/f134/opencpn-beta-version-4-8-10109-a-195843-11.html#post2558749
Her er også en liten kommentar fra sjefsprogrammereren av OpenCPN, vedr. disse rosa kryssene:
http://www.cruisersforum.com/forums/f134/opencpn-beta-version-4-8-10109-a-195843-11.html#post2558103
"If you look at Object Query, you may see that the pink crosses are mostly underwater obstructions with depth less than surrounding depth area. Sometimes least depth is known, sometimes not.
In either case, the obstruction should be shown always, since it may be a significant hazard to navigation."
Da er denne saken grei for mitt vedkommende ihvertfall!:wink:
Ha en God helg alle sammen!
Ship o' hoi:sailing:
Seastar:thumbsup:
Seastar
Seastar
Her er også en liten kommentar fra sjefsprogrammereren av OpenCPN vedr. disse rosa kryssene:
Seastar:thumbsup:
Seastar
Seastar
Seastar:thumbsup:
