Does anyone recognize these transducers ?
Vronsky
Upper one is a thru-hull, most likely with a small fish-shaped transducer fairing on the outside. Old Simrad perhaps? Sad to see anyone could get the idea of using chipboard(!!) as a backing plate for this.. maybe thread was too short, and now the backing are just going back to nature :nonod:
Lower picture may be a 'depth transducer' glued to the hull from the inside, to feed a simple depth display.
No.1 is defenitely a thru hull type, does look similar to the Seafarer tranducer that was fitted in our old Viksund 27.
And no.2 is an inside "puck" type tranducer, could be a Humminbird?
Rolf
som trives best med Sommer, Sol og Sørland
"Seier venter den, som har alt i orden - held kalder man det. Nederlag er en absolutt følge for den, som har forsømt at ta de nødvendige forholdsregler i tide - uheld kaldes det"
Roald Amundsen
