PiperBill
PiperBill
Neida jeg liker heftige diskusjoner :-)
Fra dette document.
https://www.properzi.com/literature/category/4-copper-rod-and-wire?download=10:factors-affecting-electrical-conductivity-of-cu
The second influencer of (“residual”) resistivity is attributed to structural imperfections such as dislocations, which are produced in great numbers during work hardening. Consequently, electrons can travel more easily through the conductor when it is in the annealed condition. Electrical conductivity of cold worked copper can be 3 % lower compared with the same material in its annealed state.
Om det har noe å si tviler jeg på
PiperBill
PiperBill
Fra dette document.
file:///C:/Users/William/Downloads/factors%20affecting%20electrical%20conductivity%20of%20cu%20-%202011%20(2).pdf
