000
000
Hva  skal man med routes i en slik båt? vel vel
Raymarine Dragonfly 7 PRO Navionics+ also provides the possibility to save waypoints and tracks, having a capacity to store up to 3,000 waypoints, and 15 tracks with 10,000 points each. Waypoints can also be categorized, the unit being able to store 100 waypoint groups, with up to 3,000 waypoints per group. But evidently, if one group has 3,000 (which is the maximum amount for one unit), you won’t be able to save other waypoints in another group. Saved waypoints and tracks can be imported and exported via microSD card.
Can I create Routes?
Dragonfly only supports Waypoints and Tracks.  There is no Route function
Ellers står det en finfin artikkel å lese her om hva den gjør best. http://www.rosareke.no/forsteinntrykk-raymarine-dragonfly-7pro-med-navionics-plus/
000
000
