Popeye70
Popeye70
Kjellg skrev 13 minutter siden:
QC3 har noe som heter INOV. Den takler alle enheter med spenning på mellom 3.2 og 20V med 200mv inkrement, om jeg ikke husker helt feil.
Du husket nesten riktig:
«How does it work? Quick Charge 3.0 employs Intelligent Negotiation for Optimum Voltage (INOV), an algorithm which allows your portable device to determine what power level to request at any point in time, enabling optimum power transfer while maximizing efficiency. It also supports wider voltage options, allowing a mobile device to dynamically adjust to the ideal voltage level supported by that specific device. Specifically, Quick Charge 3.0 offers a more granular range of voltages: 200mV increments, from 3.6V to 20V. That way your phone can target one of dozens of power levels.»
(fra https://www.qualcomm.com/news/onq/2015/09/14/introducing-quick-charge-30-next-generation-fast-charging-technology)
Popeye70
Popeye70
Kjellg skrev 12 minutter siden:
Du husket veldig riktig:
