Morebas 17 information required
Craig Morebas 17
Hi guys, my name is Craig  and I recently brought a Morebas 17 to use  around the coastal waters of Falmouth Cornwall England,  it's been a great boats in the little time I've had it,the Engine it has is a 2000 model Johnson 90hp 2storke, i'm just after some more information on the boat, The specification , is the engine already have too big for it or couldn't go bigger etc? With thanks Craig.  Sorry if this is posted in the wrong forum thanks again??
image.jpeg.f01180b6fdb7979673febc5a330169db.jpegimage.jpeg.e0f3f3fd16855a4794d828065e3e963f.jpegimage.jpeg.493076628761e5ad055945f4414f93a9.jpegimage.jpeg.8fd445f8d52a1e24445da3321c725c39.jpegimage.jpg.55528587f568d36c213ddabe7fc7e3b3.jpg
I believe it is made for up to 120 hp. Came from the factory with 60-120 hp.
It probably handles more on a calm sea, but I would have reinforced the rear of it first.
Nice boat!
Yes. Weight is an issue. This boat can start to "jump" with the bow (wobbling up and down?) if it's too rear heavy. Adding smart tabs have helped others to make it run smooth.
Personally I like the E-tech engines, but never had one myself :wink:
I've seen 85 listed as recommended max.
A yamaha 90 4-stroke (in norway sold as 80 and 100 hp) is listed at 165 kg,
which year is your 90hp?   the earlier crossflow engine was 140 something, the later loopers were around 164 IIRC.
Redigert av ivar (see edit history)
