Er det mulig å få ut motor VP D6 fra Scand Dynamic 9200 uten å kutte i skroget?
Amafine
31 minutes ago, Amafine said:
Forsøkt Agder Boats. De svarer at de ikke vet sikkert........ Jeg mistenker at motor er satt inn før "overbygget" er montert.
My engine are different instead  of a D6 i have 2 x 8.1LV8 That is also tight.
i could only remove the engine when i removed the drives.  this way i got some clearance in height..
And after removing the filters the was just enough room to make a turn to get them out.
The engine cover had to be removed totally including the bolts of the cylinder suspension.
I dont know how your oil pan is situated. I hope it helps.
Redigert av doctordre (see edit history)
Kjenner ikke denne båten, så et bilde hadde vært nyttig.
Hva er forresten årsaken til at bunnpannen har rustet i stykker?
