tobixen
tobixen
Av en eller annen grunn pleier jeg å gå ned i vekt når jeg er på båten, det skjønner jeg ikke. Ølkonsumet går opp, spiser neppe sunnere eller mindre mens jeg er på båten, og skrittelleren på mobilen registrerer vesentlig mindre aktivitet enn mens jeg er på land.
Fant tilbake til en ferieblogg fra 2018 nå, men observerte det samme da skolen startet opp og koronaoppholdet på båten var over. Jeg hadde forventet å gå opp i vekt, men gikk ned.
- https://hive.blog/blog/@tobixen/summer-vacation-2018-alone-in-copenhagen-and-some-rantings-about-the-grass-on-the-other-side-of-the-fence
Here is another observation; I had been out in the sailing boat for four weeks. For three of those weeks I had been drinking massive amounts of beer. Except for the last week I had been eating quite some unhealthy food. While being on a boat, one doesn't do that much exercise ... there isn't room for a lot of walking or running while being on the sea. And yet ... when coming home I stepped on the scale, and I could hardly believe my eyes ... 87 kg, that's pretty low for me, there is at least a decade since last time I saw such numbers. Going to work the next day, I climbed the hills without getting out of breath, same with the stairs at work.
tobixen
tobixen
