Raymarine ST60 Tridata Sammen med ST 40 Bidata
Thoma_s
Har en ST 60 Tridata som funker fint.
Kjøpte en lang Sestalk kabel og en ST40 Bidata for å se dybde ute. ST60 står inne.
Problemet er at 40 bare viser temperatur og ingen dybde.
Må 60 settes opp riktig?
Må 40 settes opp riktig?
Tenkte at så lenge Seatalk kabelen sender temperatur må vel dybde info og komme?
Noen som har et godt tips?
Connections to the instrument You can connect your instrument: • Directly to the depth transducer as a stand-alone master instrument. When connected in this manner, the instrument must be connected to a suitable power source using the 1 m (3 ft) power cable provided. • As part of a SeaTalk system either as a repeater or, with a transducer also connected as a system master. To connect to SeaTalk, you will need an additional SeaTalk Interconnection Kit (Part No. E25028). When connected in this manner, power can be provided from the SeaTalk bus (e.g. from the autopilot). You can also connect the instrument to both the depth transducer and SeaTalk. When thus connected, the instrument will be the master depth instrument for the SeaTalk system.
http://www.busse-yachtshop.de/pdf/rayst40echolot.pdf
