Hvilken anoder trenger du til våren?
anodemannen
Denne alu-anoden fra Sleipner skal jeg sette på min Side-Power SE60 før sjøsetting, kjøpt hos Aktiv Marin Lillestrøm (Bestmarin).
Her hva Sleipner selv sier:
  • The mil-spec alloy includes about 5% Zinc and a trace of Indium to prevent oxidation resulting in a layer reducing the sacrificial properties of the anode.
  • Provides more protection and will last longer than zinc anodes of the same size (up to 50% longer).
  • Less than half the weight of of a similar sized zinc anode.
  • Provides superior support compared to zinc anodes in fresh or brackish water, while still giving excellent pro­tection in salt water, and is the only anode that is safe for all applications.
Link til deres egen side: https://sleipner.no/produkt/16930/anode-aluminium-se6080100/
Anode, aluminium, SE60/80/100
SP55/75/95
106 kr Anbefalt utsalgspris inkl. MVA
