Teresa
Teresa
Var en tråd om dette tidligere i år. Legger ved et utklipp fra brukermanualen til min Mercury F20 E EFI:
"Operating in Freezing Temperatures
When using your outboard or having your outboard moored in freezing or near
freezing temperatures, keep the outboard tilted down at all times so the
gearcase is submerged. This prevents the trapped water in the gearcase from
freezing and causing possible damage to the water pump and other
components.
If there is a chance of ice forming on the water, the outboard should be
removed and drained completely of water. If ice should form at the water level
inside the outboard driveshaft housing, it will block water flow to the engine
causing possible damage."
https://baatplassen.no/i/topic/159719-ising-på-utenbordsmotor/?tab=comments#comment-2268693
Teresa
Teresa
Var en tråd om dette tidligere i år. Legger ved et utklipp fra brukermanualen til min Mercury 20 E EFI:
components.
