Popeye70
Popeye70
If you take a look at this picture, you can see how the bigger and smaller boats are distributed throughout the harbour. Your boat can dock anywhere, the bigger boats are usually restricted to the two outer, floating jettys due to depth restrictions.
%3Ffile=_stre_Bol_rne_0229_92793356.jpg&
Popeye70
Popeye70
If you take a look at this picture, you can see how the bigger and smaller boats are distributed throughout the harbour. Your boat can dock anywhere, the biger boats are usually restricted to the two outer, floating jettys due to depth restrictions.
