Fuglen
Fuglen
This is a very rare boat, you will not find many off that kind.
I hope you will take well care of it.
I can't help, and afraid others don't have drawings for this Draco either.
But I hope you are lucky, and someone have this.
If not, 12V electricity is not that difficult.
It just takes time to fix, when you must dissmantle inventory, crawl in/under/behind everything.
Use tape and pen, mark everything before you dissconnect.
Extra care with + and -, dont mix them.
There should be much info on internet.
Maybe someone on baatplassen could post a typical electric scheme in a boat here for you?
I see it is a twin engine boat.
Is it engine electric (charge, start, alarms, indicators, powertrim etc.) you need to upgrade?
In that case, inform what type of engines is installed, and maybe someone have that as well.
Fuglen
Fuglen
I can't help, and afraid others can't either.
