Theguy
Theguy
Forgot a line
I'm not sure if my other post git posted, so here it is again:
The image shows how the heat exchanger looks, I'll clean it out with pipe cleaners, and then figure out the systemrens bit.
Is there a water inlet on the drev that needs checking too to see if it's blocked?
I saw both anodes, so I know what to remove. Do I just replace them with normal bolts while the systemrens does its thing?
Theguy
Theguy
