Mercury 4hk 4 takt 2003+
Fred
Jeg er helt sikker på at motoren er den samme. Se tekn info under fra marinepower.no
Type: 4-takter
Effekt: 4,5 kW
Motorstyrke: 6 hk
Sylindervolum: 123 cc
Vekt: 25 kg
Type: 4-takter
Effekt: 3,7 kW
Motorstyrke: 5 hk
Vekt: 25 kg
Type: 4-takter
Effekt: 3 kW
Motorstyrke: 4 hk
Vekt: 25 kg
på marinepower.com står det enda mer info
4 hk
Models 4 SAILPOWER
Kilowatts 2.9 kW
Max. RPM at Full Throttle 4500-5500
Cylinders 1
Displacement 123 cc
Starting Manual
Gear Ratio 2.15:1
Gear shift F-N-R
Steering Tiller
Alternator System Standard with rectifier
Trim Positions 6 & shallow water drive
Fuel tank Integrated fuel tank 1.1 litre
Fuel requirements Unleaded 90 RON min.
Weight 25 kg
Recommended Boat Transom Height Long 508 mm
Induction System 2-valve pushrod
Counter rotation N/A
5 hk
Models 5
Kilowatts 3.68 kW
Cylinders 1
Displacement 123 cc
Starting Manual
Gear Ratio 2.15:1
Gear shift F-N-R
Steering Tiller
Alternator System Optional 4 amp (50 watt) lighting, 2 amp (25 watt) charging
Fuel tank -
Weight 25 kg
Recommended Boat Transom Height Short 381 mm - Long 508 mm
6 hk
Models 6
Kilowatts 4.4 kW
Max. RPM at Full Throttle 5000-6000
Cylinders 1
Displacement 123 cc
Starting Manual
Gear Ratio 2.15:1
Gear shift F-N-R
Steering Tiller
Fuel tank -
Weight 25 kg
Eneste som skiller her er maks turtall på 6 hestern.
