Jeg fant, jeg fant! Trenger du det?
Batdilla
  • 2 uker senere...
Sakset fra passagemaker.com:
Siemens (ELFA) diesel electric system for sale.
Purchased from FEYS as a package to power my planning hull boat, it will be removed in april 2008 as the boat is being repowered.
This single diesel Engine (generator) setup, allowing two shafts to be powered, can be incorporated and used in a number of different configurations, ideally suited for displacement yachts.
Plain and simple,this system was configuired to use a 600 hp diesel (at 2800 rpm) as the main generator thru twin electric v-drives, geared onto two shafts. A Gethome power option is also incorporated and was powered by a 20kw genset.
All of the systems are fully functional but would require Siemens technician to do a final commisioning. A detailed list of components offered for sale can be emailed on request.
The system is here in Hong Kong and can be shipped as required.
Her er muligheten til å bli grønn og miljøvennlig og få slutt på de menneskelige klimautslippene!! Løp og kjøp!!
Denne har jeg sett på i mange år nå. Ligger rett ved der og nesten bor om sommeren.. :lol: Ser ut som er bra og overkommelig porsjekt.
http://www.finn.no/finn/boat/object?finnko...s=8&tot=111
Redigert; Endret litt på annongseteksten for å unngå missforståelser.. :yesnod:
Redigert av Seilaren (see edit history)
God samvittighet skyldes ofte dårlig hukommelse.
Fritjof Brandt
