Verdens største dieselmotor
Javi
Sakset fra en engelsk side om denne motoren. Derav de merkelige målene.
Some facts on the 14 cylinder version:
Total engine weight: 2300 tons (The crankshaft alone weighs 300 tons.)
Length: 89 feet
Height: 44 feet
Maximum power: 108,920 hp at 102 rpm
Maximum torque: 5,608,312 lb/ft at 102rpm
Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
Legg også merke til at den bruker ca. halvparten så mye drivstoff som våre dieselmotorer for å produsere en HK. Nå går denne på Heavy Fuel som har en høyere brennverdi (egenvekt ca. 0,95) enn diesel, men alikevel...........
