Kartplotter både oppe og nede: hvordan?
chiko
Spurte :cool: og her er svaret
Svein,
As requested please find listed below general product information, unit pricing, detailed technical data sheet and mechanical outline drawings for our model VT151XHBL
Model VT151XHBL
Configuration # VT151XHBL-2-RS-0-00
Completely Sealed Case Rated IP68 Watertight.
15.1" Color TFT Active Matrix LCD Flat Panel.
XGA Native Resolution, 1024x768 pixels.
800 nit Daylight Readable Brightness.
Exceptionally Wide Temperature Range.
Shock Resistant Adjustable RAM Mount or Panel Mount
Thin Profile Anodized Aluminum Case.
Finish: Black anodized with a bright dip chemical film which UV stabilizes the color. This eliminates the normal finger prints that makes straight anodized finishes look dirty and produces a mat finish cutting down on glare.
Drilled and Tapped for Optional Panel Mounting.
8-30 VDC (12, 24, 28 VDC nominal) or 120/240 VAC Source Voltage.
Analog Resistive Touch Screen
Cables with Connectors Included
Warranty Period: Two Years
Lifetime Technical Support
Unit Price: US $4680.00
Available Options
-Integrated Heaters for Extended Low-End Operational Temperatures
-Alternated Mechanical Configurations
-Full-Range Manual Dimming
-Automatic Sensor Dimming
-Volume Purchase Discounts, as applicable
Should you have any questions, comments or further requirements please feel free to contact me.
Sincerely,
Mark Frakes
Sales Manager
Vartech Systems Inc.
800-223-8050
225-298-0300
225-297-2440 fax
mfrakes@vartechsystems.com
