abbor Startet 14.November.2007 Link til dette innlegget Startet 14.November.2007 (redigert) Garmin presenterte mandag mye nytt utstyr for 2008. De største nyhetene var nok deres første autopilot og en 15" multifunksjonsskjerm (plotter) GPSMAP 5215. Også GPSMAP 4010 med 10' skjerm ble introdusert. Autopiloten har en listepris på 4-5000 USD i USA og kommer ikke på markedet før Q3 2008. Plotterene kommer i Q1 2008. Autopiloten er en Nautamatic TR-1, som regnes som den beste piloten som finnes, som har fått en ny og bedre betjening. Garmin kjøpte Nautamatic for noen måneder siden. GHP™ 10 Marine Autopilot System with GHC™ 10 Garmin International is pleased to announce the new GHP 10 marine autopilot system which includes the new GHC 10 helm control display. For powerboat captains who want the ultimate in control and safety, Garmin’s new GHP 10 autopilot system delivers powerful performance in any sea condition. The GHP 10 is approved for Mercury Verado outboards and works with all types of hydraulically steered powerboats – inboards, outboards and stern drives. The GHP 10’s patented Shadow Drive™ technology lets you make manual course changes from the helm without manually disengaging the autopilot or “wrestling” the system for control. Simply turn the wheel for instant course changes on the fly. Then, once you’ve steered the boat onto its new course, just release the helm and the GHP 10 will automatically resume control. With its aerospace-derived technology and G-limited gyro turn control, the GHP 10 responds effortlessly and safely at virtually any speed. It can easily be set to hold position against wind, waves or heavy current. Styled to match other units in Garmin’s family of marine products, the GHC 10 is the dedicated control unit for the new GHP 10 autopilot featuring a 3.5” color display. Up to three GHC 10 controllers can be interfaced to a single GHP 10, allowing autopilot functionality in multiple stations on the boat. Product Features and Specifications • Patented Shadow Drive technology – allows users to make manual course changes without manually disengaging the autopilot • No failure prone rudder angle sensor needed – calculates rudder command from a combination of compass, gyro and engine inputs • Stress-free turns based on the G-force felt by its included rate gyro • Whether accelerating or decelerating, the GHP 10’s response is fast, precise and automatic • GHP 10 autopilot includes one GHC 10 helm control display – up to three GHC 10’s can be interfaced to a single GHP 10 autopilot system • GHC 10 helm control display has a simple user interface making user operation a cinch • Installation wizard helps users to automatically configure the GHC 10 helm control display • GHC 10’s Display: 3.5” TFT QVGA color LCD display (320 x 240 pixels) • GHC 10 has a new through-chassis mountable case design – removable top and bottom snap covers provide for easier flush mounting • GHC 10 unit dimension: 4.4” H x 4.3” W x 1.9” D (11.1cm H x 10.9cm W x 4.8cm D) • Interface: NMEA 2000 (GHP 10 & GHC 10), NMEA 0183 (GHC 10) • GHP 10 supply voltage: 10V to 20V • GHC 10 supply voltage: 7V to 32V • GHP 10 & GHC 10 operating temperature: -15° C to 70 C° (5° F to 158° F) • Users can configure the GHC 10 to automatically turn on when power is applied • The GHP 10 performs so well, it even works in reverse GPSMAP® 5215 • Display: 15-inch, color XGA resolution (1024 x 768) sunlight readable display with touchscreen – 1200 nits of brightness • Unit dimensions: 15.5”W x 11.7”H x 5.7”D Redigert 14.November.2007 av abbor (see edit history) Sitér dette innlegget Link to post
roaldbj Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Flott informasjon. Spennende lesing. Det er ikke lett å følge med i hvem som kjøper opp hvem. Jeg har lett litt etter informasjon om Nautamatic. Lurer på hva som er grunnlaget for å si at denne autopilotene regnes som den beste som finnes? Sitér dette innlegget Link to post
Mulligan Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Det lurer jeg også på. VOR, Vendee og alle andre bruker NKE autopiloter. Sitér dette innlegget Link to post
Mix Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Raymarine fikk NMEA prisen for beste autopilot i år. Og hvor ble det av Nautamatic og NKE da ? Sitér dette innlegget Link to post
Mulligan Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 NKE vinner ikke priser bransjen tildeler seg selv. De vinner regattaer. Sitér dette innlegget Link to post
Sydvesten Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Dette var spennende nytt, spesielt 4010 plotteren, da må jeg frem med tommestokken igjen når innbyggingsmålene er klare... 4008 passer, 4012 litt for stor.... håper 4010 passer... formoder den vil havne mellom 4008 og 4012 i pris... rundt 2000$ eller litt under.. Sitér dette innlegget Tar forbehold om skrivefeil i alle mine innlegg, slik at de som utelukkende er opptatt av mine skrivefeil og meg som person kan kose seg med det de kan.. Mine innlegg er også basert på min mening og oppfatning omkring temaer både her på forumet og i samfunnet ellers, dette gjelder også om det ikke er tatt eksplisitt forbehold om det i selve innlegget.. Det er bare de som føler seg underlegne som er beskjedne - de dyktige fryder seg over det de har utførtJohann Wolfgang von Goethe 1749-1832 Link to post
abbor Svart 14.November.2007 Emnestarter Link til dette innlegget Svart 14.November.2007 Nautamatic Søk på autopilot og TR-1 for å finne info om piloten, Nautamatic navnet brukes forholdsvsis lite. Utsagnet om at Nautamatic TR-1 Gladiator er den beste autopiloten er basert på utallige poster jeg har lest på diverse amerikanske forum. Eierene av TR-1 er virker som om de nærmest har et religiøst forhold til piloten sin. NMEA priser deles vel nærmest demokratisk mellom medlemmene. Raymarine som ikke engang har klart å få designet vekk rorreferansen for andre motorer enn Verado har i hvertfall ikke de beste pilotene. Eneste konkurent til TR-1 er Simrad AP-26, men shadow drive som er muligheten til å gripe rattet for å korrigere kursen uten å koble ut piloten og det at piloten også virker ved bakking gjør at det nok ikke er noen tvil om hva som er den beste piloten. TR-1 er pilot for motorbåter, NKE som jeg aldri har hør om før finnes vel bare for seilbåter. Sitér dette innlegget Link to post
abbor Svart 14.November.2007 Emnestarter Link til dette innlegget Svart 14.November.2007 (redigert) Veiledende pris på 4210 er 2464USD. GPSMAP 4210 Redigert 14.November.2007 av abbor (see edit history) Sitér dette innlegget Link to post
Mulligan Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 [NKE som jeg aldri har hør om før finnes vel bare for seilbåter. Åneida. Den stopper også motoren hvis du faller overbord. Faller du overbord fra seilbåt går den opp i vinden. Sitér dette innlegget Link to post
Sydvesten Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 (redigert) Da havner den nok rett på underisden av 2k, noe som er brukbart... 4012 selges for 2249$ og 4008 for 1769$ Da er frågan, passer den i pidestallen.... Redigert 14.November.2007 av Sydvesten (see edit history) Sitér dette innlegget Tar forbehold om skrivefeil i alle mine innlegg, slik at de som utelukkende er opptatt av mine skrivefeil og meg som person kan kose seg med det de kan.. Mine innlegg er også basert på min mening og oppfatning omkring temaer både her på forumet og i samfunnet ellers, dette gjelder også om det ikke er tatt eksplisitt forbehold om det i selve innlegget.. Det er bare de som føler seg underlegne som er beskjedne - de dyktige fryder seg over det de har utførtJohann Wolfgang von Goethe 1749-1832 Link to post
roaldbj Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Har ikke du nylig kjøpt en Raymarine fjernkontroll Sydvesten, eller har du allerede solgt din? Sitér dette innlegget Link to post
Sydvesten Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Fjernkontroll er til han Raymond, og han lever i beste velgående, funket i allefall sist torsdag da jeg flyttet båten..... men plotteren blir nok av typen Garmin siden jeg føler meg fortrolig med dette fabrikatet... Sitér dette innlegget Tar forbehold om skrivefeil i alle mine innlegg, slik at de som utelukkende er opptatt av mine skrivefeil og meg som person kan kose seg med det de kan.. Mine innlegg er også basert på min mening og oppfatning omkring temaer både her på forumet og i samfunnet ellers, dette gjelder også om det ikke er tatt eksplisitt forbehold om det i selve innlegget.. Det er bare de som føler seg underlegne som er beskjedne - de dyktige fryder seg over det de har utførtJohann Wolfgang von Goethe 1749-1832 Link to post
abbor Svart 14.November.2007 Emnestarter Link til dette innlegget Svart 14.November.2007 Har vært en tur inne på sidene til NKE og for meg ser dette ut til å være et produkt for seilbåter. Godt mulig det NKE kan brukes på en motorbåt med innebordsmotor, men siden de ikke har noe produkt for utenbordsmotorer er dette uansett uinteressant for meg. Sitér dette innlegget Link to post
Mix Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Raymarine som ikke engang har klart å få designet vekk rorreferansen Aha, forstår. Du snakker om autopiloter til påhengsmotorer. Det er nok noe annet ja. Sitér dette innlegget Link to post
Mix Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 NMEA priser deles vel nærmest demokratisk mellom medlemmene. Akkurat, det er en demoktatisk avstemming av bransjen. Demokrati er noe dritt. Sitér dette innlegget Link to post
abbor Svart 14.November.2007 Emnestarter Link til dette innlegget Svart 14.November.2007 Og da blir sannsynligvis NMEA vinnerene like grå og middelmådige som de som velges inn på stortinget De gjeveste prisene går på rundgang mellom Furuno, Simrad, Garmin og Raymarine. NMEA er viktig som en standariseringskomite, prisene derimot deles ut av selskapsklubbdelen. Sitér dette innlegget Link to post
Mix Svart 14.November.2007 Link til dette innlegget Svart 14.November.2007 Ja, akkurat det er nok ingen tilfeldighet, disse du nevner har ofte de beste produktene. Men nå har både Nautamatic og NKE og 500 andre produsenter stemmerett da. Kanskje disse har blitt stemt inn på 4 og 5 plasser i alle år, ikke mye å slå i bordet med det. The winner takes it all. Sitér dette innlegget Link to post
abbor Svart 18.November.2007 Emnestarter Link til dette innlegget Svart 18.November.2007 (redigert) Nå har også Raymarine presentert sin nye autopilot serie, SPX serien. Disse har fargedisplay, støtter SeaTalk NG (NMEA 2000), alle modeller har gyro og utenbordsmodellene trenger ikke rorføler. Raymarine XPS autopiloter Ingen info foreløpig på Raymarine sidene. I tilegg til standardmodellene vil det komme spesialmodeller for IPS, for konstantgående pumper og versjoner for kabelstyring. Ny software kan lastes fra C, E og G-serie instrumenter. Simrad har også kommet med 2 nye modeller AP24 og AP28. Det nye på disse modellene er at all kommunikasjon er NMEA 2000. Det er foreløpig ikke kjent om dette skjer på standard NMEA 2000 kabler enn om de bruker sine egene SimNet kabler Simrad AP24 Simrad AP28 Redigert 18.November.2007 av abbor (see edit history) Sitér dette innlegget Link to post
Mulligan Svart 18.November.2007 Link til dette innlegget Svart 18.November.2007 SimNET er NMEA 2000 på CAN bus. Sitér dette innlegget Link to post
Douro Svart 18.November.2007 Link til dette innlegget Svart 18.November.2007 Nå har også Raymarine presentert sin nye autopilot serie, SPX serien. Disse har fargedisplay, støtter SeaTalk NG (NMEA 2000), alle modeller har gyro (Utheving med fet tekst i sitatet ovenfor er foretatt av meg) Hei, abbor, Jeg mener at det er viktig å påpeke at de nye Raymarine-autopilotene ikke har gyrokompass. De benytter selvsagt alle fluxgatekompass som refererer seg til jordmagnetismen. Men det som er en nyhet, er at autopilotene i tillegg til fluxgatekompass også har rate-gyro, som gir en spesielt stor nytte når det anvendes sammen med fluxgate kompass. Sitér dette innlegget Link to post
abbor Svart 18.November.2007 Emnestarter Link til dette innlegget Svart 18.November.2007 I den verden jeg kommer fra kalles MEMS baserte rate-gyroer normalt bare for gyroer. Har diskutert slike komponenter mange ganger med en professor som sitter med mange patenter på området og har aldri hørt han bruke noe annet utrykk enn MEMS gyro. Vi bruker slike komponenter i noen av produktene våre så jeg kjenner godt til hva en slik sensor gjør. Jeg er også klar over at et gyrokompass er noe helt annet. Det kan nesten virke som begrepet gyro har har forskjellig betyding i forskjellige miljøer. Analog devices bruker rate-gyro, gyro og gyroscope omhverandre i sine beskrivelser av ADXR komponentene sine. Analog Devices iMEMS Gyroscopes Sitér dette innlegget Link to post
Sydvesten Svart 19.November.2007 Link til dette innlegget Svart 19.November.2007 Du bør nok ikke være så lemfeldig med beskrivelsen din her abbor, det er alltid en eller annen som kommenterer dette... Men de av oss som har Raymarine og er litt bevandret i denne verden er klar over at det som normalt betegnes som "rategyro" ikke er en et ekte gyrokopass, men gjør ikke noe stort nummer av det.. Sitér dette innlegget Tar forbehold om skrivefeil i alle mine innlegg, slik at de som utelukkende er opptatt av mine skrivefeil og meg som person kan kose seg med det de kan.. Mine innlegg er også basert på min mening og oppfatning omkring temaer både her på forumet og i samfunnet ellers, dette gjelder også om det ikke er tatt eksplisitt forbehold om det i selve innlegget.. Det er bare de som føler seg underlegne som er beskjedne - de dyktige fryder seg over det de har utførtJohann Wolfgang von Goethe 1749-1832 Link to post
abbor Svart 19.November.2007 Emnestarter Link til dette innlegget Svart 19.November.2007 Nå står det vel ingen plass definert at en gyro er det samme som et gyrokompass, gyro brukes som kortform for gyroskop. Klassiske gyroskop består av en gimbalopphengt roterende masse. I dag er de fleste gyroskoper implementert som MEMS sensorer. Sensoren har et vibrerende elment som påvirkes av rotasjon og avleses elektrisk. Et gyroskop kan brukes som byggeblokk for å lage et gyrokompass. Jeg kommer nok sikkert også i fortsettelsen til å bruke betegnelsen gyro om rategyro siden det er den betegnelsen som vanligvis brukes i elektronikkindustrien. Søket "MEMS gyro" gir 18.900 søk på Google, mens +MEMS +gyro gir 303.000 treff så det er ikke bare jeg som er lemfeldig med mine betegnelser. Sitér dette innlegget Link to post
Oliver Svart 19.November.2007 Link til dette innlegget Svart 19.November.2007 Garmin eller Raymarine? Skal kjøpe plotter og valget står mellom Garmin 525s og Raymarine A60. Er det noen med erfaringer på disse to? Garmin har noe høyere oppløsning, men bare 5 " skjerm. Raymarine har 5,7" skjerm. Begge har ekkolodd. Sitér dette innlegget Link to post
VannTro Svart 19.November.2007 Link til dette innlegget Svart 19.November.2007 Jeg kjøpte Garmin 525s i sommer og synes i hvert fall skjermen er stor nok. I min forrige båt hadde jeg Garmin 188c som også hadde 5 toms skjerm, der hadde jeg koblet opp ekkolodd-funkjonen og kjørte med split-screen, mer enn stor nok skjerm. Du må soome litt ut oh inn, men den har veldig rask prosessor så det går som en drøm. Den nye Garmin 525s har også en funksjon hvor du legger inn stedet du skal til og så beregner den ruten og ankomsttiden/reisetiden, dette er en super funksjon selv om jeg stort sett ikke er helt enig i rutene den anbefaler. Den har også en del kule, men helt unødvendige skjermbilder som for eksempel fishermans eye, men de er som sagt mer kule enn nødvendige.... Bra nøyaktighet og rask prosessor samt flottte kart ! Sitér dette innlegget Medlem av: KNBF - RS - Holmestrand Båtforening - Holmen Motorbåtforening - Norsk Trawler Klubb - Clipper Klubben Båthistorikk fra 1975: Pioner 11(med rør-ramme) - 3hk Evinrude Yachtwin / 1979 Pioner 8 - 4 hk Johnson / 1983 With 300 Dromedille - 35hk Evinrude / 1979 Viksund 27 Columbi - Yanmar 3QM30 30hk / 1977 Marex 23 DC - Mercruiser 319D 180hk / 2005 Askeladden 525 Excel - Mariner 90 2-takt / 1987 Fjord 880 AC - FordSabb 2728T / 2011 Clipper 36 Sedan - Cummins QSB 5.9 230hk. Link to post
