Kan Kad300EDC tilkobles Raymarine E120 via NMEA?
so vest
Interessant spørsmål.
Jeg har selv en KAMD300 med EDC. søkte etter det på nettet men fant ingenting.
Det står heller ingenting om det i brukermanualen.
Så at det var noen som hadde koblet GPS signal til EDC for å få inn fart... så kanskje det går andre veien også ?
Du kan jo høre med Volvo.
Hilsen
Lykkeliten IV
(på båtjakt)
Her er hvad jeg tror/ved:
For at kunne trække motor-data ud gennem NMEA-2000 kræves det et separat NMEA2000-interface. Dette er kun kompatibelt med nyere D-serie-motorer. Ikke engang min egen D6-310-A kan tilsluttes et sådant :-(
Derfor tvivler jeg også på at den ældre KAD300 kan - men det enkle svar er jo at spørge Volvo.
Andy
Hei det er muligheder at koble sammen "gamle" motorer mot NMEA 2000.
Det her er sakset fra Ask Jack Rabbit
Boat Guy: You should check out the soon-to-be-released product from NoLand Engineering. The MD33 is an elegant solution for older engines needing NMEA2000. The basic principle is to sample the analog gauge readings, as well as pulse rates for tachometers and fuel flow meters, then convert those readings into NMEA2000.
JackRabbit: This product is shown on the Noland website as a pre-announcement of an upcoming release. I spoke to Noland yesterday and learned that their goal is to release the product before the end of the first quarter.
The device has interfaces for one or two engines and connects to the analog signal wires on the back of the existing analog gauges (or anywhere else in the harness where they might be accessible). The raw input, in the form of DC voltages, goes through a USB port to a PC, where it is processed and displayed onscreen by the Noland software included with the interface. As each make of engine may have different scale factors for different sensors, the user has to set up the scale factor through the software (e.g. a scale factor is needed between the voltage on the engine temperature sensor input and a temperature reading, to know how to convert the voltage for display). Eventually, as experience is gained with different engines and gauges, configuration files can be provided for standard setups.
NMEA 2000 messages are created within the PC software and then sent back down to the interface unit for transmission over an NMEA2K network. This means that the PC has to be on, and running the Noland software, for there to be any engine data on the network. Ideally, at a later stage, Noland would set it up so that the PC could download the scale factors to the interface once configuration was complete. Then the unit could work without the need for a PC connection other than at initial setup and it seems to me that this would make the product a lot more attractive to those who don't have an onboard PC, or have a laptop onboard but don't use it while under way. But this needs more processing power in the interface than is available right now.
Expected list price for the unit will be "under $1000" says Noland.
vh Brusi
Redigert av Brusi (see edit history)
  • 9 år senere...
