English: Methode for conserving a old SABB diesel?
p_homan@zonnet.nl
First of all: Clean out all oil in the crankshaft housing, and refill with fresh new oil. Take out thr start cigarette holder, and give it 5-6 pumps of oil into the cylinder. Then take off the valve cover on top, and oil the valve mechanism thoroughly. Turn the engine round with the decompression handle open a few turns to distribute the oil. If you want to do even more, spray the outside of the engine with for instance CRC's 6-66.
