Offeranoder i kjøler KAD300
hermansen
jeg kikket på kjølesystemet på KAD 300 på www.marinepartseurope.com. Her ligger sprengskisser for alle VP motorene. Jeg kunne ikke finne noen anode her.
her er delelisten
No. Description PartNo. Qty Price
1 Heat exchanger 3586706 1 2 312,70
(3580886)
2 Cover 3581033 1 271,99
3 O-ring 925027 1 6,24
4 Gasket 964106 1 1,39
5 Screw 963567 1 3,48
6 Sealing strip 860127 3 2,16
7 Plug 861551 1 5,03
8 Bracket 860391 1 117,71
9 Bracket 860392 1 117,71
10 Bracket 3581467 1 53,30
11 Flange screw 946440 1 0,51
11A Spacer 3850090 1 3,26
12 Lock nut 948645 1 0,69
13 Flange screw 965226 1 2,40
13A Spacer sleeve 843122 1 3,11
13 Spacer sleeve 861554 1 3,30
14 Lock washer 940143 1 0,24
15 Support ring 838733 2 26,55
16 Stay 860450 1 54,01
17 Flange screw 945444 1 0,51
18 Lock nut 948645 1 0,69
19 Screw 965193 1 1,23
20 Stud 953002 4 4,75
L=125mm
21 Nut 971095 4 0,53
22 Stud 17378 2 12,78
L=170mm
23 Nut 971095 2 0,53
24 Hose 3581099 1 141,84
Heat exchanger-expansion tank-water pump.
25 Hose clamp 943477 1
26 Hose clamp 943474 1
27 Hose 861109 1 129,66
Thermostat housing-heat exchanger.
28 Hose clamp 943477 1
29 Hose 861340 1 54,70
Oil cooler - heat exchanger.
30 Hose clamp 943476 1
31 Hose 861341 1 45,60
Heat exchanger-exhaust riser.
32 Hose clamp 943476 1
33 Expansion tank 3580941 1 63,60
34 Stud 953003 2 12,93
34 Stud 953005 1 11,93
35 Bracket 3581040 1 59,71
36 Nut 971095 3 0,53
37 Flange screw 946544 1 0,53
38 Spacer sleeve 3581032 1 8,94
39 Rubber ring 3285120 1 2,73
40 Washer 976944 1 0,53
41 Screw 968999 1 2,63
42 Hose 942700 X 5,36
Expansion tank-Turbo., L=760mm
43 Hose clamp 945652 2 0,70
44 Hose 942700 X 5,36
L=580mm, Expansion tank-thermostat housing.
45 Pressure cap 1674083 1 26,30
46 Screw 967949 2 0,53
47 Clamp 952627 2 0,53
