Simrad CX44 relativ lite zoom
Nor Star 350
Her er hva manualen (engelsk) sier om range / zoom:
4.1.4 Range or zoom function
With chart display active:
1-9 Press one of the numeric keys to quickly change the chart scale:
[1] = 1:600 [2] = 1:2,000 [3] = 1:6,000 [4] = 1:20,000 [5] = 1:60,000 [6] = 1:200,000 [7] = 1:600,000 [8] = 1:2,000,000 [9] = 1:6,600,000
- Press the minus key to zoom in for details (smaller range)
+ Press the plus key to zoom out for overview (greater range)
Using the extended level range will give the best result when changing chart range. First use one of the numeric keys (Quick-Range 1-9) to select the required chart, then 'fine tune' the range within the same chart level by using the +/- keys. Depending on the actual chart, you can zoom in or out two to three times before the extended level range is switched off and the chart changes to a new level of details.
The extended level range can be toggled OFF/ON in General settings (default = OFF) - see section 4.5 Chart setup.
Chart details may not be available in all scales in all areas. Noncovered areas will be marked as hatched or all blue/white with coordinate grid (when Grid is set to AUTO (default) in chart setup), depending on the actual scale - see section 4.5 Chart setup for more details in regard to what can be shown on the chart and what you may choose not to have shown.
Redigert av Svenning (see edit history)
