Oljetype og nivå på powertrim Mariner 50 HK
nomen
Ifra manualen...
Fill, Check, and Purge - Power Trim
System
TO FILL:
IMPORTANT: This trim system is pressurized. Remove
“Fill” plug only when outboard is tilted to
the full “Up” position or the trim/tilt rams are fully
extended. Retighten “Fill” plug before tilting outboard
down or retracting tilt/trim rams.
Remove “Fill” plug and O-ring. System is full
when oil level is present at fill hole. Tighten “Fill”
plug securely
Trim engine to full “up” position. Engage tilt lock lever.
Trim system fluid can only be checked when engine
is in this position.
Slowly remove fill screw and check fluid level. Fluid
level should be visible in fill tube.
If necessary, add Quicksilver Power Trim and Steering
Fluid or Automatic Transmission Fluid (ATF) Type
F, FA or Dexron II to power trim system.
Reinstall fill screw; tighten screw securely.
Tilt motoren helt OPP FØR du åpner påfyllings skruen på babord side (kommer ut igjennom babord motor feste .
Eventuell lufting gjøres ved å kjøre motoren helt opp/ned 3 > 4 ganger .
Arne Kjetil
