Yafinn Startet 29.August.2010 Link til dette innlegget Startet 29.August.2010 Hallo. Jeg har hatt noen problemer med min båtmotor den siste tiden. Har prødv å finne ut av hva som kan være galt. Jeg la inn et innlegg på et amerikans forum, men ingen svar sålangt. Håper på at jeg kanskje kan få et svar her :) Jeg håper det går bra uten at jeg må oversette fra engelsk til norsk! Om det ikke er greit, si ifra. Sitat I've had a few problems with my outboard. It's a Yamaha 115hp V4 - 99mod. What happened the day it stopped working I started it as usual. It went just fine at idle, then I accellerated I got 100 meters then the engine lost all it's power and then I died. I tried to start it again, but it was barely any reaction. Started almost, then choked itself. Then I did some troubleshooting, but couldn't really find any obvious reasons why it suddenly died. I thought maybe it was some spark issues, but I think the ignition is OK. Then the day after, I tried to start it again. But now it wouldn't start at all. Just almost start, then died. We changed all spark plugs, then it started and went perfect at idle. Even when I tried to give full throttle at idle it went up to 5k RPM without any problems. But once I put in in gear, it just *bluuurph*, almost no reaction. Then I pressed the auto choke, and *VROOOOM* went perfekt. Then I let go of the choke, and it slowly died again, but it didn't stop completely. Just went at 600 RPM at full throttle. I did this test over and over again, and it was repeatable. When I used choke, it went perfect. Then I and the guy I had with me, though: "It doesn't seem like it gets enough fuel." So we checked the fuel hose and all the connections, but it was OK. Then we decided to check the fuel pump, to see if it was OK. But honestly, we don't know if it is OK. I dismantled the fuel pump and I noticed.. There are 2 very thin aluminum-"things" (don't know the name of them) in each chambers inside the fuel pump. Then.. One of those, in each chamber was not 100% tight. When you pressed them, you could hear a "click". There is a small gap between them - not much, but maybe it is enough for the pump to stop working correctly? Anyways. I mounted the fuel pump back together, mounted it back on the engine. Then I tried to start the engine again, but now... I wouldn't even go normal at idle. It started, but died after just a few seconds. Not even giving throttle at idle worked. I will check the mounting of the fuel pump tomorrow, just to be sure it's mounted correctly. It seems like the pump is in bad shape? Or can it be something else that **** it up? Maybe some inpuries? Please. Let me hear some of your experiences. It's a long ride to the nearest outboard repair shop, so I try to do as much as I can before I capitulate, and take it to the repair shop And... If there is anything you want to ask me, that may help you to help me, just shout out. Sitér dette innlegget Link to post
OnkelDonald Svart 29.August.2010 Link til dette innlegget Svart 29.August.2010 Hei! Har du pumpebelg på slangen til motor, får du den til å gå hvis du pumper bensinen manuelt? Høres ut som et bensinmangelproblem. Sitér dette innlegget Genialt enkel redigering av nettsider Link to post
Yafinn Svart 29.August.2010 Emnestarter Link til dette innlegget Svart 29.August.2010 Det er nok mest sannsynlig mangel på bensin, ja. Spørsmålet er jo... Er det bensinpumpen eller er det rusk i forgasseren? Den gikk ikke noe bedre da jeg pumpet manuelt, men jeg merket at trykket var dårlig siden jeg kunne pumpe en del med den. Sitér dette innlegget Link to post
ivar Svart 29.August.2010 Link til dette innlegget Svart 29.August.2010 har du tilgang til annen bensintank / slange du kan forsøke med? Har sett at selve bensinslangen kan lage trøbbel , koblingene kan trekke falsk luft og ventilene i blæra kan slite så mye at de ikke klarer å forhindre at bensinen renner tilbake på tanken. Det er også overhalingssett til bensinpumpa å få kjøpt, det bør du kanskje ha uansett siden du nevnte at ventilene virket noe "slappe" Sitér dette innlegget Lurøy / Svalbard. Båter: Gromling 15/60 Yamaha / Wesling 490 m/80 Yamaha / Yamarin 5940 m/ F115 Yamaha / Achilles LS4 (RIP) Aquaquick MS265 West Commando 270 m/ 4hk Yamaha Link to post
Yafinn Svart 29.August.2010 Emnestarter Link til dette innlegget Svart 29.August.2010 (redigert) ivar skrev On 29.8.2010 at 14.50: har du tilgang til annen bensintank / slange du kan forsøke med? Har sett at selve bensinslangen kan lage trøbbel , koblingene kan trekke falsk luft og ventilene i blæra kan slite så mye at de ikke klarer å forhindre at bensinen renner tilbake på tanken. Det er også overhalingssett til bensinpumpa å få kjøpt, det bør du kanskje ha uansett siden du nevnte at ventilene virket noe "slappe" De ventilene som er der. Følger de med det rep.settet? Er det noen steder man kan få bestilt det online fra en norsk nettbutikk? :D Du mener kanskje at tanken kan være et problem? Hm, det må jeg vel kunne få sjekket ut, tror jeg. Redigert 29.August.2010 av Mortex (see edit history) Sitér dette innlegget Link to post
ivar Svart 29.August.2010 Link til dette innlegget Svart 29.August.2010 tank+slange, kan uansett være greit å få sjekket ut Sitér dette innlegget Lurøy / Svalbard. Båter: Gromling 15/60 Yamaha / Wesling 490 m/80 Yamaha / Yamarin 5940 m/ F115 Yamaha / Achilles LS4 (RIP) Aquaquick MS265 West Commando 270 m/ 4hk Yamaha Link to post
Yafinn Svart 29.August.2010 Emnestarter Link til dette innlegget Svart 29.August.2010 Er jo en fasttank (plastikk) som jeg kjøpte ny i fjor. Samme med slangen. Men jeg skal uansett sjekke det ut :) Sitér dette innlegget Link to post
Kasper22 Svart 29.August.2010 Link til dette innlegget Svart 29.August.2010 Har du sjekket vannutskiller,bensinfilter,drenert forgasserene ? Kan vere vann i bensinen.. Sitér dette innlegget Link to post
Yafinn Svart 29.August.2010 Emnestarter Link til dette innlegget Svart 29.August.2010 Kasper22 skrev On 29.8.2010 at 16.41: Har du sjekket vannutskiller,bensinfilter,drenert forgasserene ? Kan vere vann i bensinen.. Vannutskiller/bensinfilter er det nok ikke siden jeg koblet slangen rett fra tanken til motoren hvor samme problem oppstod. Drenert/renset forgasserene har jeg ikke gjort, siden jeg håpet å slippe det. Jeg tok av igjen pumpen nå for å sjekke. For å si det sånn... Det kom overhode ikke noe bensin ut fra slangen mellom pumpe og forgasser da jeg koblet den fra, men det var litt bensin i det andre kammeret i bensinpumpen. Tror det er pumpen som er defekt? Sitér dette innlegget Link to post
Kasper22 Svart 29.August.2010 Link til dette innlegget Svart 29.August.2010 (redigert) Hvis du har fått vann inn i forgasserene hjelper det ikke å kjøre på med ren bensin, da du først må få ut vannet. Du spurte "Er det bensinpumpen eller er det rusk i forgasseren?" Hvis ikke du har vannutskiller i båten, så ta en titt i bensinfilteret. Finner du vann i bunnen av koppen der, så vet du hva problemet er. Hvis du lurer på om pumpen fungerer drar du av slangen og ser om det pumper ut bensin.. Edit: Regner med du sjekket at membranen var hel da du demonterte bensinpumpen Redigert 29.August.2010 av Kasper22 (see edit history) Sitér dette innlegget Link to post
