Har noen vært borti Seabreacher?
Mjøsfarer
Dette her må vel være et leketøy for viderekommende.
Teksten under linken er sakset fra hjemmesiden deres.
Link til Seabreacher X
The Seabreacher X is the latest and most advanced submersible watercraft that we have built to date: This exciting new version is based on the dolphi- inspired Seabreacher J, but it has a more aggressive Shark-style body. The X model also steps up the performance envelope with a 260hp supercharged engine, propelling the vessel to a top speed of 50mph on the surface and 25mph below.
The Seabreacher X can sustain high speed dives and then breach the surface, launching the entire vessel clear out of the water. The new fully vectored thrust system mimic the tail articulation of real aquatic animals like sharks and dolphins. The custom tuned exhaust system also gives the vessel a more throaty growl as it tears across the surface.
Some other high tech features: a snorkel mounted video camera transmits live video to LCD screens for the pilot and passenger during dives, GPS navigation, and on board stereo system with iPod docking
The Seabreacher X is a limited edition model and Innespace will only be producting a total of 10 of these vessels. Reserve yours today!
Engine / Drive
* ROTAX 1500cc, 4 stroke engine
* 260 hp supercharged, Intercooled
* high output, low emission,
* Axial Flow jet pump
* Fully vectored thrust (up/down, left/right)
* Forward, Neutral, Reverse
* Closed cooling system, reliable in fresh or salt water
* All components can be serviced at your local watercraft dealership
Features
* Re-designed shark style body
* Mouth-shaped viewports for enhanced underwater visibility
* Double snorkel intakes for engine's increased air requirements
* High performance, low profile wings and elevators
* Powder-coated stainless steel and alluminum hardware
* Custom exhaust outlet
* Fully upholstered interior, customized to your desires
* Front and Rear LCD screens, displaying live video from snorkel-mounted camera
* Onboard stereo system with ipod dock
* Removable lifting eyes for launching from a yacht mounted davit
* Custom built powder coated trailer
Safety
* Hand-laid composite, monocoque structure
* Positively buoyant, self-righting hull design
* 1/2 inch, impact-resistant, acrylic canopy
* Inflatable aircraft seal keeps cockpit and engine bay water tight
* Three automatic bilge pumps
* Collapsible nose section in the event of frontal impact
* Break-away wing tips
* All marine approved engine components and hardware
* Onboard fire extinguisher and carbon monoxide detecter
* U.S. Coastguard inspected
