OBS! Innkalling av alle 2010 mod. MerCruiser Bravo og Alpha drev
adeneo
Brunswick Marine har sendt ut "Recall Notice" for drev produsert av Marine Power International Pty Ltd under navnet MerCruiser Bravo eller Alpha.
Problemet ligger i girsystemet, og kan gjøre at girsystemet slutter å fungere.
Jeg limer inn den orginale meldingen under, slik at alle som har drev som er berørt kan lese den. Det oppfordres til å snarest ta kontakt med den lokale forhandleren, som vil utbedre feilen kostnadsfritt.
Exclamation Notice: Recall for 2010 Model Mercruisers with Alpha or Bravo Drives
Product Make: Mercury MerCruiser Stern Drives Packages (power boat engines)
Product Models: MerCruiser 4-cylinder, V-6, V-8 petrol and 4-cylinder, 6-cylinder diesel engines Stern Drive models supplied with Alpha & Bravo Transoms Assemblies.
Models Affected:
Transoms Shipped With MerCruiser Engines
Engine Serial Number
Transom Serial Number
Alpha
1A602571-1A621587
1A194127-1A68107
Bravo
1A350418-1A621253
1A437945-1A444913
Loose Transoms
(Spare Parts)
Alpha 1A194127-1A468107
Bravo 1A437945-1A444913
MC1 0A845988-0A846138
Marine Power International Pty Ltd has become aware that certain MerCruiser Sterndrive Packages require replacement of the Intermediate Shift Cable to ensure the safety and reliability of your MerCruiser package.
The intermediate shift cable connects the engine's remote throttle and shift control unit to the stern drive's gearshift mechanism. If the shift cable core fitting becomes detached, the operator will be unable to change gears (forward, neutral, reverse).
To determine whether a gearshift cable is affected by this recall, the cable date code stamped on the barrel of the cable jacket (on shift bracket end of the cable) needs to be inspected and possibly replaced.
People with an affected engine (as per the above table) should immediately discontinue use and contact their nearest MerCruiser, Mercury or Mariner Dealer who will arrange for the engine to be inspected and rectified at the expense of Marine Power International Pty Ltd.
