Bitteliten
Bitteliten
denne lille karen leveres med en ekstern PMG
"The Piccolo is equipped with a PMG module (Power Module Genverter) to ensure that the voltage and frequency for all selected RPMs remain perfect so that all the equipment works correctly."
i brukermanualen til PMGen står det:
 The Power Module for Genverter (WP-PMG) is an essential link between your WhisperPower Genverter and your AC electrical system. It contains both an engine control module and a 230VAC pure sine wave inverter, and it acts as a user interface to your Piccolo genverter system. WhisperPower Genverters are state-of-the-art generators using very compact and highly efficient Permanent Magnet alternators to produce electric power. Unlike traditional fixed speed generator sets, however, Genverters may produce output voltages up to 440VAC with frequencies as high as 400Hz. From this, the WP-PMG produces a stable sinusoidal AC voltage at 50Hz, as required by regular 230V appliances. Safety is enhanced by WP-PMG’s capability to blow fuses when a short-circuit occur
. Whisper Power Norge sier at man kan justere ned turtallet på motoren for å fjerne vibrasjoner og ressonans uten at det går utover outputen fra kraftverket, og det er kanskje nettopp det denne inverteren fikser?
Bitteliten
Bitteliten
Usikker på hva de gjør. Whisper Power Norge sier at man kan justere ned turtallet på motoren for å fjerne vibrasjoner og ressonans uten at det går utover outputen fra kraftverket.
