Cummins, VW og Mercruiser går sammen
rogeri
Følgende info poppet inn i mailboxen her om dagen.
Formidler denne selv om det for mange er "gamle nyheter" at Mercruiser og Cummins har holdt på en stund!
Cummins MerCruiser Diesel and Volkswagen Forge Strategic Alliance
Marine propulsion systems manufacturer Cummins MerCruiser Diesel and
Volkswagen have announced a long-term alliance to co-develop marine engines
below 5 Liters that will be marketed, distributed and serviced under the
CMD brand.
Key to the alliance is the planned joint development of marine engines
below 5 Liters that will comply with future emissions standards.
Volkswagen, a leading manufacturer of diesel marine engines up to 350 hp
(258 kW), will manufacture the new engine line at its plant in Salzgitter,
Germany. Additionally, effective January 1, 2011, all current Volkswagen
marine engines will be sold exclusively by CMD and marketed under the CMD
brand.
The EPA Tier 3 emissions standard will take effect in 2012 in the United
States, and the RCD2 emissions standard takes effect in 2014 in Europe for
this range of engines. The new standards prescribe significantly lower
thresholds for emissions of nitrogen oxides (NOx) and other pollutants and
require the development of next-generation diesel combustion technology.
“Our alliance will not only culminate in new products that set the
ecological benchmark in their class, but will also bring added value with
regard to reliability, reduced noise and vibrations, size, weight and power
density, and will complement the complete line of engine, drive and
helm/control systems currently available from CMD.”
CMD is a global provider of marine propulsion systems with a worldwide
distribution and service network, and it possesses industry-leading control
systems and integration capabilities”.
In connection with the agreement, the CMD distribution network, beginning
Jan. 1, 2011, will start assuming responsibility for service and
administration of warranty claims for engines previously sold under the
Volkswagen Marine brand.
For engines above 5 Liters, CMD will continue to marinize Cummins base
engines in the Charleston, S.C., and Darlington, UK, facilities. The QSB,
QSC, QSL and QSM engines are capable of meeting EPA Tier 3 and Europe RCD
Tier 2 emissions standards with in-cylinder strategies similar to those
being deployed for engines resulting from this alliance with Volkswagen.
About Cummins MerCruiser Diesel Marine, LLC:
Based in Charleston, South Carolina (USA), Cummins MerCruiser Diesel is
responsible for designing, manufacturing and providing reliable after-sales
support worldwide for marine propulsion products. It offers a broad range
of power, with available ratings from 115-715 hp for recreational
applications and 150-715 hp for commercial use. Cummins MerCruiser Diesel
is a joint venture between Cummins Inc. and Mercury Marine and can be found
on the internet at www.cmdmarine.com.
Until then, we thank you for your continued support,
Everyone at Cummins Norway AS
Applausen ville ingen ende ta.... :tongue:
Gleder meg til at strenge utslippskrav tas i bruk her også, host, host.
Mange båtmotorer er særdels dårlig justert?
Må vi alltid ligge etter amerikanerne, eller er kravene blitt like strenge her hjemme?
Kravene tok vel fart etter at utslipp fra biler dannet smog over Los Angeles og skapte sykdommer.
Når disse 3 selskapene slås sammen så menes det vel alvor, skal bli artig å følge utviklingen.
