Ønskar synspunkt på dette Fulibatteriet
Ask
Hei
Eg er takksam for synspunkt på dette batteriet. Teksten nedanfor er kopiert frå databladet.
Eg får ikkje til å kopiera heile databladet difor er teksten nedanfor ikkje i tabellform.
Databladet kan sendast direkte til dei som ønskar det.
Ask
DC SERIES
DC (Deep cycle) Series batteries are designed for deep
discharge application, with special chemical formula for plates
active paste material, slightly stronger electrolyte and low
temperature design, which can withstand repeated deep cyclic
application, such as Solar Energy System, Golf Trolley, Electric
General Features
Sealed and maintenance free operation.
Non-Spillable construction design.
ABS containers and covers(UL94HB, UL94V-0) optional.
Safety valve installation for explosion proof.
High quality and high reliability.
Exceptional deep discharge recovery performance.
Low self discharge characteristic.
Flexibility design for multiple install positions.
Construction
Component .....Raw material Sealant ........Epoxy Resin
Positive ........Lead dioxide Safety valve ....EPDR
Negative ........Lead Terminal ........Copper
Container ........ABS Separator ........Fibre glass
Cover ........ABS Electrolyte ......Sulfuric acid
FL121500DC
20HR(7.7A,1.75V)
154AH
Length
485mm(19.09inch)
10HR(15A,1.75V)
150AH
Width
172mm(6.77inch)
5HR(25.5A,1.75V)
127.5AH
Height
240mm(9.45inch)
1HR(96A,1.75V)
96AH
Total Height
240mm(9.45inch)
Full charged at 25oC: 0.004 Ohm
3% of capacity declined per month at (25oC)
102% 100% 85% 65%
Cycle use Float use
14.4-15V(-30mV/ oC), max. Current: 37.5A 13.6-13.8V(-20mV/ oC)
40oC 25oC 0oC -15oC
46Kg (101.43lbs)
Battery Model
Capacity(25oC)
Dimensions
Approx. Weight
Internal Resistance
Self Discharge
Capacity Affected
by Temp.(20HR)
Charge Voltage(25oC)
Designed Cycle Life > 350 cycles @
Synes det ser ut som et greit batteri uten at jeg skal påberope meg å ha noe greie på det. Ser de veier litt mindre (1,5kg) en Victron Energi sine som jeg kjøpte, og at sluttspenningen ved 20hr kapasiteten er 1,75 V/cel mot Victron sine 1,8V/cel.I mitt hode sier det at Victron sitt batteri er et hakk vassere/mere kapasitet.Pluss for detaljert datablad tilgjengelig som jeg synes gir troverdighet.
