Om skikkelige seilere...
GeirKS
Denne er rappet fra news og skrevet av en original som kaller seg "Simple Simon", eller noen ganger Capt. Neal hvis jeg husker korrekt.
Tenkte den var på sin plass her blant oss småskravlende bryggeseilere.
You know you're NOT a REAL SAILOR when . . .
--your propeller costs more than you mainsail
--your motor costs more to replace than your working sails
--your boat has more hulls than spars
--your boat goes faster under power than under sail
--your stereo is newer than your standing rigging
--your foul weather suit cost more than your binoculars
--your diesel tank holds more than your drinking water tank
  and is filled more often
--your dinette table is bigger than your chart table
  and is used more often
--you have a built-in microwave oven and a hand-held GPS
--your windlass costs more than your anchors
--your LPG tank(s) have more capacity than your fire extinguisher(s)
--you carry radar but no Coast Pilot, Tide Tables and Tide Current Tables.
--your radar costs more than your chart collection
--your radar is newer than your chart collection
--your steering wheel is bigger than your arm span
--you have more winches than sails
--your engine weighs more than your provisions
--your holding tank gets more use than your shit bucket
--your batteries weigh more than your anchors
--your cabin sole has more varnish on it than your teak flag pole
--your davits are worth more than your dinghy
--your utility bills have more stamps on them than your passport
--your log contains the word "dock" more than the word "anchor"
--you have a driver's license but not a Captain's license
--you think the COLREGS are for the protection of miners
--your CD collection is current but your flares are expired
--your stereo is louder than you loudhailer
  Sitat
Veit da søren jeg GeirKS. Kan denne karakteristikken passe på noen av forumets eminente lang-seile-wannabees mon tro ?
:rolleyes:
Suzuki
No boat needed..
  Sitat
:rolleyes:
Suzuki
Jammen, hva med alle de andre punktene da?
Gnom!  :boxing:
Tror jeg skal sende en klage til raadet ang. mobbing.
GeirKS
  Sitat
Tror ikke jeg er særlig mottakelig for mobbing fra en som har som hobby å sy  :cool:    Fnis...
GeirKS
den kommentaren skal du få ete i deg. Når du kommer "begging" om å låne min siste erværvelse på gutterommet, nemlig en superduperkraftig symaskin.
Syr etter sigende sponplater
Så da så
Suzuki
No boat needed..
jeg handler ny maskin. Gidder ikke krangle med kjærringer om sånt.
Interessant psykologisk forresten, vedr. brukthandel. Mannfolk er klar over at brukte ting ikke lenger er nye, og setter prisen deretter. Kvinnfolk skal helst ha tilbake alt de selv betalte, og mere til. Snodig..
Suzuki
No boat needed..
  Sitat
Suzuki
er ikke helt med her :confused:, men låter som kjente toner fra noen år tilbake :boxing:
  Sitat
Hva skjedde egentlig med den symaskina, trodde dere hadde gjort en handel?
GeirKS
Trodde det jeg å. Ettersom den veier over 27 kg, valgte jeg å droppe å få den med meg på toget. Dro hjem, henta bilen, og troppa opp som avtalt 2030. Selger var da ikke keen på å selge lenger, da hun hadde OMBESTEMT seg. I morra er sikkert prisen satt opp til det dobbelte. Være vel penger da sikkert.
Suzuki
No boat needed..
  Sitat
(jag trodde dock det var förhandling på gang der hjemme........3 fot syke  :lol: )
Vel, min utskremte speider hadde ikke alt for mye pent å si om utpekt kjøpsobjekt ( Takk til deg LarsHerman ), så da venter vi. Dessuten er det greit at jeg eier båten, og ikke omvendt. ( mager trøst ). Vi får se, plutselig tar jeg en Bastard 3K / Walter_S vet du..
Men syproblemet ser ut til å løse seg
Suzuki
No boat needed..
