Nederlenderen Startet 3.Juni.2011 Link til dette innlegget Startet 3.Juni.2011 Jeg skal sette ny fall , what is the best way to connect the new one to the old one? nylon? Sitér dette innlegget Link to post
ÅtteGlass Svart 3.Juni.2011 Link til dette innlegget Svart 3.Juni.2011 Yes, make a few stiches with a sewing needle and some nylon twine, then cover it with a little elastic tape to make sure it won't get stuck. Sitér dette innlegget Oslo Seil- og Båtskole. Link to post
Smurph Svart 3.Juni.2011 Link til dette innlegget Svart 3.Juni.2011 I've always just duct taped the old and new halyard together, end to end, when changing. Not too much tape, three rounds should do the trick. It's held up very well and the tape has actually been quite tough to get off. You're probably safer if you stitch the ends together, too, but it's not necessary IMHO. Sitér dette innlegget Bundin er bátleysur maður Link to post
Bømlo Svart 4.Juni.2011 Link til dette innlegget Svart 4.Juni.2011 You might want to look at video - "Replacing your Halyard Rope - Sailboat Halyard Line". Sitér dette innlegget Link to post
