Fargekode yamaha
Itmas
Code   Paint Name   Comment Color Chip ColorRite Top ColorRite Base
004D  Dark Bluish Gray Metallic #2 (DBNM2)       5547
00EK  Metallic Marine Silver (MMS)  1984-1993 Standard Outboards     5546
00NA  Shiny Black (SBL)       5544    1544
00EJ  Metallic Marine Blue (MMB)  1989-1991 "C" Models     5545
008D  Dark Bluish Gray #1 (DBN1)       5364
00NG  Marine Dark Silver (MRS)  1986-1989 Pro V lower unit and lower mount covers.     5354
003P  Light Gray Metallic 9 (LNM9)  Most V-Max upper cowl air ducts.     5356
005B  Bluish Gray Primer #1 (STZ)  Bluish Gray Primer #1     5352
0098  Low Gloss Black (LGB)  Used on some props.     5654
009M  Dark Bluish Gray Primer #1 (ZNC)       5362
00EL  Harbor White (HW)  1985-1994 FT, T9.9 and some props.     5360
001S  Dark Bluish Gray Solid #9 (DB9)  Engine paint-Use to repaint engine assemblies.     5358
9S  Dark Gray  Used on Engine Components     5548
Shetland family four, mercury 135.
Uttern C 56, mercury 50.
Fibrafort style 215, mercury 150/ Yamaha 200 hpdi / Suzuki 115
Sea Ray 240 Sundanser, mercruiser 5,0 MPI
