Hvilken årsmodell på denne Honda 5hk?
skarlun
Det skal vel finnes en plate med et serienummer på motorbraketten.
Sakset fra nettet:
Compare the serial identification number with a Honda Motor Serial Identification.
The year code will be immediately after the horsepower designation. The year can begin with a A, D or K. For example, the serial number BF115A3LRTA means Honda, 115 Horsepower, 2003 Model, 20" shaft length, Remote Control, Tilt and Trim, American Market.
All Honda model numbers begin with "BF," which represents Honda, followed by the one to three digit horsepower designation. The year of manufacture is next, represented either by two letters, or a letter and a number. The shaft length, steering system, tilt and trim and "A" for American designations follow next. Year designations can be decoded as: "DX" for 1999, "DY" for 2000, "A1" for 2001 and so on, depending on which hp motor it is. Models from two to 20 hp will begin with "D" and 25 hp and up begin with "A." For decoding specifics, see Marine Engine in References.
Selv tipper jeg også rundt 1990 modell.
