Hva omfatter vanligvis en "Marine Surveyor" rapport?
NOR15186
Hei
Jeg er i ferd med å kjøpe en båt i Italia, og vurderer hvorvidt jeg skal engasjere en "Marine Surveyor" for å få laget en rapport på båtens tilstand. Etter å ha kikket på innlegg på baatplassen er jeg usikker på verdien av dette, ref. https://baatplassen.no/i/topic/96388-tips-om-marine-surveyor-takstmann-i-nord-vest-frankrike/
Er det noen som kjenner til hva innholdet i denne typen rapporter vanligvis er, og hvorvidt det er smart å benytte en "Marine Surveyor"?
Jeg er erfaren ift. båt selv, og kjenner båttypen jeg skal kjøpe godt.
Mvh.
Kajla
Hei Kajla
Jeg har nylig fått følgende beskrivelse fra en surveyor i Italia:
An outline of items inspected are as follows:
Hull & Deck Structure:
· General Visual Inspection.
· Osmosis inspection & moisture meter readings.
· Assessment of external & internal structure.
· Bulkheads, framing & reinforcement.
· Openings, ports, windows.
· Skin fittings & sea cocks.
· Steering gear.
· Stern gear.
· Stanchions, hand rails.
· Bilge pumping.
Machinery:
We will not perform compression tests.
We will make a general external inspection of the installation including bearers, hoses, fuel system and stern gear.
We will request that the engine be run under load when the vessel is back in the water.
We will take an oil sample for analysis if requested (+ 150 euros per sample).
Electrical:
General external inspection of installation, including generator (if applicable), switchboards, batteries & electrical and electronic outfit items.
And
Ground tackle.
Fuel installations.
Gas installations.
Fire fighting equipment.
Water installations.
Toilet installations.
Sea Trials:
We will perform sea trials (weather permitting) and we will be checking engine performance, paying particular attention to exhaust emissions, signs of overheating, coolant or oil leaks, vibration in the transmission and drive-line, correct operation of steering and navigational equipment, etc..
Jeg ville absolutt ikke kjøpt en bruktbåt uten at den først var sjekket av en uavhengig surveyor. Disse menneskene er fagfolk, har utdannelse og erfaring, og jobben deres er å finne eventuelle feil. Det de finner må enten utbedres eller føre til passende avslag i pris.
Det de tar for jobben kan fort vise seg å være vel anvendte penger.
