Type olje til Volvo Penta D2-55/D2-75 saildrive?
NOR15186
Hei
Jeg er i ferd med å kjøpe en seilbåt med en Volvo Penta D2-75 motor. Sjekker derfor litt vedr. vanlige problemer.
Leste på et utenlandsk forum følgende vedr. olje til D2-75 saildrive:
"They are now advocating the use of engine oil such as 15W30 (making up the oil number) instead of transmission oil. The use of ATF Oil is not recommended as they are advising customers to put the same engine oil to the transmission/reverse gear as well. On the new engines in their stands, they have put the stickers which say "15W30 oil only" on transmission/reverse gear housing as well.
They have stated that the clutch slip is a common problem and if the above solution does not work, the transmission/clutch parts need to be changed."
Er det noen på baatplassen som har tilsvarende erfaring??
Mvh.
Kajla
