Nye Windy 29 Coho - arvtageren til Ghibli
Lingefan
Båten ser fantastisk bra ut. Både moderne og klassisk på samme tid. Denne designen vil holde i mange år. Skulle jeg noen gang hoppe fra bobåt til dagsturbåt, så kommer Windy høyt opp på listen :clap:
Redigert av mrmotorboat (see edit history)
Båt historikk: HP 12 Sport m/30 hk Tohatsu (1989-dd), Sessa 21 Islamorada m/115 hk Yamaha (2002-2008), Marex 280 Holiday (2010-2011), Marex 320 ACC (2013-dd),
Er ikke Zonda etterfølgeren til Scirocco på mange måter?
Det er en 39 foter på gang. Basert på Zonda designet. Fra Duboisyachts:
Windy 39 Grand Zonda
Overview
Design work is nearing completion and mould tooling will begin in the autumn on this sleek, retro-styled dayboat, whose classic reverse sheer and wrap-around windscreen are intended as a conscious echo of Johnsen’s highly successful 31 Zonda, introduced last year.
With two double cabins and a single head with a separate shower, the 39 also features a versatile cockpit layout. This includes a clever pair of sliding seats, which can be rolled together to form a curved, aft-facing sofa. There is also a small garage in the stern which allows for the stowage of a fully inflated two-metre tender. The cockpit boasts a barbeque grill and a sink, and there is a practical galley below.
As with the 31, the 39 Zonda is conceived as a return to the pleasures of boating, pure and simple, with no gimmicks, just practical solutions. The cockpit cover with full standing headroom is designed to be as trouble-free as possible, and can be put up or down in a matter of minutes, stowing under the aft bench seat and cockpit steps. On the foredeck, a sun awning can be rigged on four carbon-fibre poles.
A true sports cruiser, the 39 Zonda will be powered by a pair of six-cylinder, 400hp Volvo diesels with Duoprop drives. These will give a maximum speed in the region of 45 knots, and economical cruising in the thirties. A roomy engine room ensures all-round servicing access and will also have space for a 4.5kW generator to power the galley and run the air-conditioning, if needed.
Redigert av Bonus (see edit history)
