Kva står bokstavane for på ATF-gearolje for?
baatmann
fra wiki-linken, ser ut til at det er spesifikasjoner som er på tur ut
History [edit]
In the 1950s, 1960s, and 1970s, ATF contained whale oil as a friction modifier. But since whale oil would break down at higher temperatures, cars produced in the 1970s and later would not be able to use whale oil because of the higher engine coolant temperatures employed to reduce emissions and save fuel. A moratorium on whale oil at that time prevented the continued production of older ATF such as the original DEXRON formulation (Type B), and the Type A which preceded it.
mer: https://baatplassen.no/i/topic/34711-slitter-med-aa-finne-atf-type-a-hydrolikk-olje
