Må ha nytt toalett! Noen anbefalinger på manuelt?
Arvor 20 Fish
Har det noe med dette å gjøre?
  • If there is ANY possibility that the discharge non- return valve may be below the top of the tank at ANY time, a ventilated anti-syphon loop must be fitted in the outlet pipework to ensure that the contents of the tank do not syphon out through the bowl.
  • Arrange the outlet hose to form a loop which is at least 8" (20cm) above the highest possible level that the top of the tank may reach, and fit the Vented Loop at that highest point.
  • 3 år senere...
