Kobling av ny start nøkkel
as1980
G= ground
B= battery+
M= magnet
S= solenoid
A = accessory circuit
bilde
Er den til en dieselmotor kan det vel være at G står for glow, altså gløding.
Ein skulle kunna tenkja i dei baner, men i den tegningen som teerex har komme opp med, so går den rett til jord.
Det er framdeles noko som skurrer baki skallen, so eg stiller to spørsmål:
as1980, hvilken motor er det snakk om?
teerex, har du noka lenke til den tegningen ?
- eg skal gjerne vera med på nøtteknekking, men ønsker å unngå sikringkasting
   Magne
http://www.boatfix.com/how/switch.html
THREE & FOUR POSITION, ON - OFF - START & ACCESSORY (OUTBOARD):
This type of switch is common in older outboard engine applications.  It has two or three active positions, ON and START.  It has been used by many major outboard engine manufacturers.  Its basic operation is to apply power to multiple circuits, as well as provide a path to ground for voltages returning from a magneto circuit.  There are four versions shown below.  Diagram H shows the standard switch.  Diagrams E, F, and G show the switch with an accessory position version.   This switch is used anywhere multiple on - off functions are required where a magneto system is involved.
