Garmin 525, får ikke lastet inn kart
Rune Totland
Tenkte det samme. Tror dette er riktig framgangsmåte for å nullstille:
To perform the master reset, please follow these instructions:
With the device powered OFF, press and hold the Home button
Press and hold the Power button
Continue to hold both buttons until the message "Do you really want to erase all user settings?" appears, then release both buttons
Highlight Yes and press the Select button
The device will now restart. When it fully boots, the device will be set back to factory default settings.
2014-2016: Nor-Dan 780 (2008 mod.)
