Nanni 4.200 2000 modell, verdianslag?
siwis
Hei!
Noen som kan fortelle meg ca salgspris på en Nanni 4.200 he fra 2000? motoren er i god stand (tilsynelatende) og har blitt overhalt. Min far døde, og etterlot dessverre lite informasjon - og vurderer derfor å selge denne separat. Det var meningen motoren skulle inn i et restaureringsobjekt - en snekke på noen og 20 for - men denne viser seg ennå vanskeligere å selge.
Håper noen kan gi meg litt informasjon.
TECHNICAL DATA
ENGINE MODEL 4.200 HE
ENGINE SPECIFICATION
Number of cylinders : 4
Displacement : 2197 cc
Bore - Stroke : 87 X 92.4 mm Compression ratio : 23/1
Max. pressure difference between cyl. :
10%
Compression pressure : 29 to 33 b
Maximum speed without load : 3000 Maximum RPM in load : 2800 Idle RPM in forward gear : 850 Max. torque :
Firing order : 1 - 3 - 4 - 2 Rotation : Anti clockwise
INJECTION
Type of injector : BOSCH
Fuel injection pressure : BOSCH NIPPO PFR4M
Injection pump manufacturer : 140 b Injection timing : 18° before top dead center
TIGHTENING TORQUE
Arm head cover cap nuts : 0.7 to 0.9 kgF/sq.cm.
Cylinder head bolts : 9.5 to 10.0 Flywheel bolts : 10 to 11
Connecting rod bolts : with coll.: 3.7 to 4.2                                    without coll.:4.5 to 5
Rocker arm bracket nuts : 2.4 to 2.8 Main bearing caps bolts : 4.7 to 5.2
Main bearing caps bolts : 7.0 to 7.5
Nozzle holder assembly : 5.0 to 7.0
Glow plugs : 2.0 to 2.5
fiche11gb
LUBRIFICATION
Oil pressure at idle RPM : 0.5 bar Oil pressure at maximum load : 3 to 4.5 bar
Recommended oil : API CD 15W40
Oil pan capacity : 6 l <angle> 7.5l
-  mini :
-  maxi :
Gearbox model : HBW
Oil capacity : depending on type
Recommended oil : ATF
DIAGRAMS
Valve clearance (cold) :
Inlet : 0.18 to 0.22
Exhaust : 0.18 to 0.25
Valve recessing : + 0.05 to - 0.15 mm
PISTON RINGS
Piston ring gap :
Piston top compression : 0.30 to 0.45 Intermediate :
Oil control : 0.25 to 0.45
CYLINDER HEAD
Cylinder head surface flatness : <0.05 mm
SEA WATER PUMP
Water flow :
GLOW PLUGS
Resistance : 0.80 ohm
