PiperBill Svart 18.Mars.2018 Link til dette innlegget Svart 18.Mars.2018 Klippet dette fra et amerikansk forum. Ser ikke helt lovende ut for batteriene dine spesielt med tanke på sikkerhet. The sulfuric acid electrolyte is a mixture of H2SO4 with H2O (water) with other chemicals to make it a gel. The H2SO4 part does not evaporate. When excessive current is forced through the battery during charging (which is very easy to do with a GEL cell), the H2O is converted into H2 gas and O2 gas, which leave the battery. All that is missing then is the water, so you do not need to add anything else back. However, the chances that you can get the water back into the proper gel mixture and in good contact with the plates is minuscule (very small). Meanwhile there are all sorts of bad things that can happen when you try to charge the damaged battery, including fire and hydrogen explosions. There is no assurance that will happen every time of course, but is it worth the risk? The only kind of battery that can sometimes be rescued from abuse is a Flooded Lead Acid (FLA) battery. And even that requires caution and is often not worth the effort. Sitér dette innlegget And always remember the wire should have a higher rating than the fuse as otherwise the wire becomes the fuse! Link to post
Morten1989 Svart 18.Mars.2018 Emnestarter Link til dette innlegget Svart 18.Mars.2018 Takk @PiperBill! da blir det vel og kassere de siden de ikke er trygge lengre :-) Sitér dette innlegget Link to post
Lars H. Svart 18.Mars.2018 Link til dette innlegget Svart 18.Mars.2018 (redigert) Vel, du kan jo teste de litt? Lad de opp og sleng på en belastning, en kraftig lyspære og se om de holder spenningen en stund. Men du sa jo at de var dårlige i utgangspunktet og du (postmannen, elskeren/elskerinnen til kompisen/deg eller tante Agathe) har ikke gjort det bedre med å fylle på vann. Redigert 18.Mars.2018 av Lars H. (see edit history) Sitér dette innlegget Lars H. Helgesen, "Kapteinen" på Trudelutt (Saga27) med hjemmehavn i Son, Oslofjorden Nettsteder jeg drifter: trudelutt.com oljepionerene.no Skipshunden vår Som Paschuan i Soten sa på 1920-tallet: Ja, inte är jag mätt, men törstig är jag. Link to post
