Hvordan Demontere seteryggene i dynamic 9200
Aake
  • 1 år senere...
Here you see all the screws of both seats.
the right side you van reach by removing the plate (red box)
To losen the side you heed to remove the top of the table(green box) and maybe one or two screws from the kitchen.
The top left you can reach from the outside (airvent)
Th ebottom two is terrible/you have to remove the back plate that is under the seat cushion.
In worse case you have to remove the seats top frame to get a better reach
  • 2 uker senere...
