Forhandler i Stavanger på VHF
Fuenge
Fant denne oppskriften engang for en NASA SX35. Jeg tror den er identisk med M-Tech 35. Så det kan jo være verd et forsøk.
RESETTING MMSI ON SX 35 DSC radio
1. Depress the MEM and SCAN button simultaneously and switch the transceiver to ON.
2. At “Factory Reset”, release the buttons and push ENT
3. Switch the transceiver to OFF
4. Switch the transceiver to ON (Display is empty)
5. Push the ENT button
6. Switch transceiver to OFF
7. Switch the transceiver to ON
Done.
You can now enter a new MMSI
