Mercruiser 1.7 dti - Low RPM
Andy B
I have problems with the engine reaching the RPM required – Mercruiser 1.7 DTI - 2004 Model
With the gear in neutral the engine will reach normal RPM and can be increased to approx. 4,400rpm. However, once the propeller is engaged the RPM only reaches up to 2,200rpm
All sounds normal up to 2,200rpm, then nothing happens when increasing the throttle, there is no change in sound or any noticeable black exhaust. The fuel rack moves with the throttle but does not have any effect. The boats hull and drive is clean, with no shells at all.
I thought it might be fuel filter, so I have changed both filters and still the same problem.
Any ideas ? Maybe turbo?
  • 2 uker senere...
