Corvin17 Posted March 29, 2021 Share Posted March 29, 2021 Er det problematisk å sjøsette båt med påhengs mens det enda er fare for et par minus på langtidsvarselet? Tenker på kjølevann og div, dreneres det godt nok når motor tiltes opp etter tur til at det tåler et par minus på natten? 0 Quote Link to post
Teresa Posted March 29, 2021 Share Posted March 29, 2021 (edited) Var en tråd om dette tidligere i år. Legger ved et utklipp fra brukermanualen til min Mercury F20 E EFI: "Operating in Freezing Temperatures When using your outboard or having your outboard moored in freezing or near freezing temperatures, keep the outboard tilted down at all times so the gearcase is submerged. This prevents the trapped water in the gearcase from freezing and causing possible damage to the water pump and other components. If there is a chance of ice forming on the water, the outboard should be removed and drained completely of water. If ice should form at the water level inside the outboard driveshaft housing, it will block water flow to the engine causing possible damage." https://baatplassen.no/i/topic/159719-ising-på-utenbordsmotor/?tab=comments#comment-2268693 Edited March 29, 2021 by Kjøttmeis (see edit history) 0 Quote Link to post
Join the conversation
